Re: Code c1142 - Pressure sensor (ABS)?
Basically, I just want to know if there is any danger of driving on this; will it cause any other damage, etc? The dealership says no, but I don't trust them.
I don't trust dealers either....
There won't be any damaged caused by a sensor failure, but you most likely lose your ABS or ABLS....If part of the ABS sets a code, the system doesn't trust it anymore, so it shuts down the ABS...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
