Old 07-10-2009, 06:54 AM   #4 (permalink)
mjw357
mjw357's Avatar
Re: Trying to Remove Factory Wheels
Clean the center hub (the part that goes thru the hole in the wheel) with a stiff wire brush or emery cloth. Check inside of wheel for corrosion, clean in a similar way. Then apply light coat of grease or anti-seize as mentioned.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
