Thread: trailer lights
Old 07-15-2009, 06:21 AM   #9 (permalink)
loufish
loufish's Avatar
Re: trailer lights
Look again, Lou, not the same guy posting.
Aw...man.....your so right...
..........but he's still killing me!
I don't know else to look. I've checked every fuse.
Go back to those 2 BCM fuses and check that you have turn/brake voltage there...If yes, then take apart the 7 pin connector and find the corroded/damaged wires...
If you have nothing at the fuses, then double check the sub-harness at the BCM...if still good, you BCM is bad...
Didn't I just write almost the same thing a little while ago...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
