Old 09-07-2004, 06:03 PM   #1 (permalink)
BigPete
BigPete's Avatar
Does Manual Shifting Stress the Trans ?
Will shifting the Titan manually put a strain on the transmission?
For some reason when accelerating with 1/2 throttle the transmission automatically shifts into 2nd gear prematurely and stays there until it slowly climbs into the 3500 RPM range where it then shifts into second. It would seem to me that if 1/2 throttle is applied the transmission should stay in first gear a bit longer. (Damn computer trying to decide when to shift via fly by wire) When shifting manually, you can accelerate smoothly in first and then through second. Pickup is much better but I worry about the additional strain on the transmission. Just to let you know, I am not winding out each gear but manually shifting at around 2800 RPM.
King Cab LE 4x4
Overhead Rack
K&N Air Charger
Banks Exhaust
Lund Bug Sheild
Eclipse AVN2454
Rockford Fosgate Punch series 301
Rockford Fosgate Punch series 401
Infinity Kaapa series 50.5
Infinity Kaapa series 63.5
Rockford Fosgate dual voice coil 8" sub
BigPete is offline   Reply With Quote
