Old 09-08-2004, 05:33 PM   #8 (permalink)
Blaze
Blaze again,
This is to answer a question to a few replies back. YES I have the Retrax cover on the Titan. YES I have the utilitrack system. It installes with four allen wrench bolts you need to drill in through the bed rail (not the utilitrack, but the actual bed rail). It took about 2 hours, but the pain in the butt thing is that the front mounting bolts are a pain, because you have to get your fingers in such a small area to start the nut, but also to find a wrench small enough to tighten it was difficult. All in all, once I was done I was happy. Also the only maintenance so far is that I take a bit of tri-flow, or wd-40 and wipe the inside of the rails every other month or when it seems sticky.
The Web site is www.rolltopcover.com
When I get home from work tomorrow morning i'll take some pics and try to figure out how to post them.
P.S. I forgot to mention that with the utili-track system you need to remove the rear stops on the track. This is because you can't turn the tie downs on 90 degrees because of the rool top cover rails. However you can slide them on and lock them down where you need them from the back. Also on the drivers side is where the locking mechanism is. If you have a tie down in the util-track rail and you go to close the roll-top, the locking mechanism can hit the tie- down. It may take a bit of nugging to get it closed.
Blaze is offline   Reply With Quote
