Old 09-08-2004, 10:44 PM   #4 (permalink)
NorCal 4x4
NorCal 4x4's Avatar
Originally Posted by Titan XE
... but it is unclear if the skid plate would still have to be removed. If so I would skip the idea.
I did not have a skid plate that needed to be removed. Have you changed your Titan's oil yet, (so that you know for sure there is a plate covering it)?
If so, what Titan model and packages do you have? I have the 4x4 Crew cab w/4x4 off-road and big tow packages. To remove the oil filter there was the small ~ 8"x 8" plate, but the drain plug was accessible, w/o plate removal. Am I missing a plate?
The plug was on very tight, so be prepared. I don't know if this is because of the crushable washer, (that needs to be replaced each time), or because of factory tightening.
Thanks,
Steve
