Old 09-09-2004, 05:44 PM   #9 (permalink)
Mike H.
Mike H.'s Avatar
Originally Posted by MXTitan
That BFG A/T 315/70-17 WILL NOT fit a stock Titan, or even a Daystar/Rough Country-leveled Titan. That tire will rub on a Titan lifted 8" if it is on a 9" or 10" wide wheel. The only way (so far) to get that tire to fit is to put CST's 8" lift on a 2WD, or CST's 7" lift on a 4WD. Bulletproof also has a 12" lift, but it will fit 37" tires I believe. Believe me, I know this because my 35" tires on 18x9.5 wheels are going to require me to cut my front valances a little bit even with the CST 8" lift.
As far as the BFG A/T goes, the 285/70-17 may not even fit without a little rubbing at full lock. It has a very square tread edge, and is known to sometimes rub a little where other "equal sized" tires don't.
Mod links (clickable):
