Originally Posted by Flafisher
As far as rotating tires, the jury is still out on whether radial tires should be swapped from one side to the other. You can search the internet and find plenty of sources but I'd check with the MFR before swapping sides on my vehicle.
Jury verdict verdict has been "in" for years. It's fine to swap sides and recommended by Ford, GM and Dodge trucks on radial tires (including BFG) not specifically marked with a uni-directional arrow on the sidewall.
It's also how you avoid, or rid your truck of steering pulls when the wheel alignment is already correct.
