Old 09-15-2004, 08:39 PM   #1 (permalink)
RCtitan04
Front tires Feathering, need advice
Hello all,
Got a XE CC that is having problems, My Front tires are feathering real bad. The tires were rotated about 7500 miles, and i now have 12500 on the truck, The pattern is kinda wierd, Basically trying to write a visual, The outer edges of the tires are feathered, and sit lower then the two out of three right on top. The Center tread is also the same as the outer, same height and feathered. Guess you can Say it looks like __--__--__
17" stock rims no offroad pkg
What would cause this, My tire pressure is as recommended 35 PSI. IVE rotated the tires at 7500 Miles and the the rears still have no odd wear.
At 7500 miles i took the Vehicle in for the rotors (warped), they ended up fixing this, now this problem is accuring..
Any help is appreciated.
Thanks
Ron
RCtitan04 is offline   Reply With Quote
