I called up RC and they said you can use any shock you want. I specifically told them I wanted to run the Bilstein 5100s and they said no problem. I value Greg's expertise but I'm getting conflicting info here. I'm wanting to run the RC 3" kit with the Bilstein set to 1" lift for a total of 4" lift up front and a 1 1/2" block rear for level-slight forward rake.
Originally Posted by sgtcheesy
thx guys i decided not to go with this kit because after speakin to Greg at PRG I'm just gonna go with the Bilstein shock and a spacer he said that if you go with this kit there isn't much room for upgrade afterward as you can only use Rancho/Monroe shocks afterwards because of the design of the kit
--i'm still curious as to how it looks and rides though
