Originally Posted by MadMax
I'm pretty unhappy to find out the 'limited slip' on this truck is a braking system that prevents you from smoking the tires- half the fun of a big v8 should be laying nice double patches off of stoplights.
you must also be pretty unhappy for me to tell you you have been misinformed.
i have BALS, and have no problem doing a burn out or kicking it lose around a corner since i DO NOT have VDC. if you didn't have BALS, you would only lay a single patch of rubber since one only tire would be spinning. BALS ensures that both tires spin, like a limited slip differential. it doesn't cut engine power.
wasn't this established on a post a LONG time ago?
