Re: kc front seats rattle
Originally Posted by salstats
k guys it aint the place were its mounted or what ever is being discuss. if you guys notice their is tap on the right upper corner if you pull it the seat will go flat on to a table and the part that folds over is the cause of the squeak if you fold it and drive or shake it. it wont squeak once you put it back to normal shake it and it will still squeak so the problem is the part that make the seat fold. lubricate that part.
ill try that but not sure if it my issue. they replaced the seat base and it went a way for a bit but someone sits in the seat and then it comes back. i belive it is in the base but you may be right ill check that out. im not getting a squeak im getting a rattle noise from the base of the seat by the way
selling my paintball guns look here---> http://www.titantalk.com/forums/buy-...ml#post1853074
2007 SE radiant silver 4x2
22x9.5 AR Marins
kumho 305/40/22 ecsta
10k hid conversion (****for sale*****)
2* advance
k&n gen II FIPK
Mcgauhys 2/3 lowering kit
superchips tuned
jba exhaust
armada front airdam
SOON:
JWT cams when they come out
Detroit Truetrac LSD
JBA headers with magnaflow high flow cats
UPREV when headers or JWT come
painted front hood cowl
hellwig rear anti-roll sway kit
upgraded front and rear brakes
