Old 09-16-2004, 10:29 AM   #51 (permalink)
MadMax
from what i've read on the abls - it works as a limited slip by applying BRAKING force to a wheel that is spinning until the rear wheels are spinning at the same rate.Thus the acronym ABLS: Active Brake Limited Slip A TRUE limited slip differential transfers POWER to both wheels allowing you to roast both tires.
MadMax is offline   Reply With Quote
