I was going to suggest a Steyr M in 357 Sig or 9mm until you said you wanted and external hammer. If you reconsider the hammer thing, take a look at the Steyr. They are reliable, easy to shoot( love the sights) and inexpensive($279.00 at gun shows).
The previous recommendations are good except I would try to avoid a 1911 if you are on a budget. The entry level guns often need a little tweaking and aren't that cheap to start with. Not always the case, but often.
A Beretta 92 is a good choice though are a bit heavier than the Glock type guns but are reliable and very popular.
My actual recommendation given your needs would be a S & W .357 and or .38 special. A model m60 perhaps. Easy to use and conceal and make safe from the kiddies.
By the way, I own several examples of all the above mentioned guns.
Kronos
2004 Titan CC LE
Born 02/03/04
