Thread: trailer brakes
Old 08-22-2009, 10:44 AM   #72 (permalink)
HRTKD
HRTKD's Avatar
Re: trailer brakes
Originally Posted by jumpy View Post
I have a leer top on my '04 CC 4X4 w/ big tow. I am thinking about hooking up camper top's third brake light and dome light to the truck side trailer wires. Any thoughts?
The Leer installer didn't already do that for you? Mine did. There are a couple of fuses that they added. As near as I can tell the power for the topper third brake light is coming through the brake light assembly (driver side) while the power for the dome light is a totally separate wire ran all the way from the battery.
If you take power off the trailer hookup then your dome light will only work when the ignition is on.
Jim
