Old 08-24-2009, 08:58 AM   #41 (permalink)
kjstanger
Re: after market trans cooler?
Originally Posted by Bulldog22 View Post
I understand that I am working my rearend harder than it was designed. But, there is no difference in the safety of my truck towing than yours. If I blow up my tranny it is a financial issue not a safety issue. My suspension is no different than yours. My tires are probably better than yours. The tires I run are far better than the junk they put on stock. The only difference in my truck and yours stock is the rear end gearing. I have the same power, suspension, trans, and cooler. I also have a Blue Ox wt. dist. hitch. I have been towing heavy loads for longer than some of you have been alive. I started on a 1979, 9 speed pete with a 53' drop deck landall trailer. I appreciate the input of the majority of the people on this site, but suggesting that my rearend gearing is a safety issue is bogus.
Didn't mean to upset you, you definatley have more experience than me on towing. Just wanted to make sure you don't damage your truck with the amount of weight you are towing but living where you live you probably won't have an issue. I live in Ga. and tow in the Ga. mountains which is why I needed the tow pkg.
2007 Titan SE Crew, Tow pkg, Popular pkg and Hard Tonneau Cover
kjstanger is offline   Reply With Quote
