Old 09-24-2009, 04:38 PM   #35 (permalink)
paradysz
Re: Titan Lift and Shock Overview
is this good? Performance Accessories Premium Lift Systems offer an affordable solution for truck and SUV owners. Combining Performance Accessories' body lift, leveling kit, and gap guards, Premium Lift Systems are the most economical way to raise your vehicle between 5 - 6 inches. Premium Lift Systems deliver the most lift for the money of any lift solution available today! Premium quality and appearance, without the premium price tag!
Kit Contains:
3" Performance Accessories Body Lift Kit
2.5" Spacer Leveling Kit
Gap Guards
All Necessary Hardware & Detailed Instructions
Additional Information:
Maximum Tire Size: 33"
Stock Shocks Are Retained!
Body Lift Features:
AFFORDABILITY: Performance Accessories body lift kits are a very affordable option when considering lifting a vehicle; in some cases a Performance Accessories body lift can be as much as 3 times less than a comparable suspension system.
RIDE: Since body lift systems do not alter or change suspension components there is no deterioration of the quality factory ride.
WARRANTY: Since Performance Accessories body lift systems do not change or alter factory parts, the factory warranty is not affected.
GREATER APPLICATIONS: Due to our professional engineering staff, Performance Accessories is usually the first to offer a lift for new vehicles or difficult to fit vehicles. Performance Accessories also offers body lift kits for many diesel applications.
LARGER TIRES: The primary reason for a consumer to lift their vehicle is that they want to install larger tires and wheels. A body lift from Performance Accessories allows the consumer to increase two to three tire sizes.
2WD vs. 4WD: Most Performance Accessories body lift systems fit both 2WD and 4WD vehicles. With 2WD kits available back in the 1980's Performance Accessories was the first to market with a lift for 2WD vehicles.
VALUE: When you combine the many reasons listed above, Body Lift systems from Performance Accessories are by far the best value when lifting a vehicle.
Tech Notes:
Will not fit vehicle equipped with diesel engine.
Steering extension included.
Rear bumper brackets are to enhance appearance only, bumper cannot be used for towing.
Requires cutting the lower radiator core support and installing new brackets provided.
Front end alignment highly recommended.
tell me what you think
5.5" 04-09 Nissan Titan Premium Lift System/Kit - Top Gun Customz
paradysz is offline   Reply With Quote
