Re: Need help with towing.
Originally Posted by felix55
So you believe if I get a correct size drop down hitch and level the trailer out completely straight I should be fine with having no sway?
im telling you i pull enough things even with my truck lifted. get you about a 10-12" drop hitch, pull the rhino all the way up and call it a day. you might get a little sag and that may actually help level the trailer.
2007 KC 2wd White
modswanted:
UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
REPLACEMENT BUMPERS
SAS
MODS DONE!
REMOVED ALL THE DECALS,TINT,S&B CAI, 4" RAM AIR MOD,5" BULL HAULER STACKS W/3" Y PIPE, BALLISTIC OFFROAD JESTER'S 17X 9 -12MM OFFSET, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 38.5x14.50x17 SUPER SWAMPER TRUXXUS M/T, 3"BODY LIFT, HITCH, 2-JL AUDIO W6V2 10", CUSTOM FORWARD FIRING BOX BY SLWILSON6, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER, BURNOUT MOD, LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, BULLY DOG GT TUNER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS, DDM 35W 8000K LOW BEAM, DDM 35W 8K HIGH BEAM, MILE MARKER 12,000LB WINCH, 3 8" PRO-COMP 130WATT OFFROAD LIGHTS, MY MADE FRONT BUMPER WITH WINCH MOUNT, LINE X BEDLINER, LINE X ROCK SLIDERS, LINE X ROCKER PANELS AND BOTTOM OF THE BED, 10.5" INGSIGNIA MOTORIZED FLIP DOWN SCREEN, SONY XPLOD W/ BUILT IN BLUE TOOTH AND AUX PORT, BACK UP CAMERA, BLACK PAINTED INTERIOR PANELS, BEDLINER FRONT AND REAR BUMPERS, DANA 60 WITH 4.56'S W/ POWERTRAX LOCKER AND BEDLINERED, BEDLINERED B/W POCKET STYLE FENDER FLARES,
www.myspace.com/stuntin4alivin, facebook http://www.facebook.com/home.php?ref...&id=1811942692
