Thread: DVD System??
Old 10-02-2004, 07:11 AM   #14 (permalink)
Titanparts1
Originally Posted by RS250R
Mine is a Myron and Davis and it comes in grey or tan to match the major upper console colors. the screen specs are:
7.8" 16:9 wide screen TFT LCD active matrix
1440H x 234W resolution
.358H x .413W dot pitch
400 cd/m2 bightness
50/60/65/65 (top, bottom, left, right) degree viewing angles
wireless ir for head phones
You do not have to use the wireless on the M&D. Just do not plug in the audio source an it does not send a signal. I am going to tap into the factory harness going to the audio unit where the dvd feed normally goes per llajumpvid's suggestion in a previous post by him.... really it is all his fault I started this ;^) after reading his post and seeing his system.
llajumpvid - I followed your posts and was unable to find the DVD harness under the dash in my TITAN with the popular with bench and mid-level audio. apparently the harness is different if you do not have the center console. Instead I am going to have to remove the audio unit to get to the harness behind it. hopefully the wires are there in the mid-level plug or at least the pins are there. BTW, where did you get you line-level amps?
Thanks for the offer on the FM Modulator Jamie. It is just not for me. I am having enough problems with FM reception (even post TSB) that I do not want to go that way.
I have found a couple of sub-harnesses, 1 in the center console behind the radio for a dvd system, and 1 for the roof console for the dvd system. They might help you to tap into the factory system!
24016-7S202 center console $42.74
24167-7S261 roof console $25.73
I'm not exactly sure if these would help, someone would have to be a guiney pig!
-Jamie
Check out our site:
www.titanparts247.com
Titanparts1 is offline   Reply With Quote
