10-11-2009, 05:14 PM
#5 (permalink)
Re: Need new coilovers with PRG mid travel kit?
Originally Posted by MrStevie
Thanks, i'll be ordering his kit in november as long as no surprises come up  . What does his kit come with? Just lca's and uca's
sorry, missed the last little bit of your post  That won't give me any more travel over what i have now until i change out the coilovers though, right?
You can buy it complete or just parts, Also it is now known you can get upwards of 17" of travel with a 10" travel shock.
of course you have to remove the coil bucket and fab a custom shock hoop/mount for the extra travel.
5,OK, im not gonna lie about this and throw some rubber-ruler number out there. With shocks, steering, and everything, 12+ inches. I wish I could lie and say 16, but its just not possible with a bolt-on kit. The upper limit is the inner fender, the drop limit is the lower ball joint or coil bucket or tierod (they all hit about the same time slightly different points depending on how you cycle it). With the CST spindle on a 2wd with modified steering, you can get about 1 more inch of droop (or 13+ total). For comparison, the CST lt kit gets 15" of travel. Even, my truck only cycles 15". With a properly valved/spring 2.5" coilover and the airbumps mounted out on the arm as we are doing, it will work really, really well.
We will be racing MDR (1450) on this kit by the end of the season (but with modified coilbucket and inner fender for 3" coilovers, 2.5 bumps and more travel, 14+ inchs looks possible without the inner fender). I will hopefully destroy evey weak link on the truck to find the weak spots so we can further improve the reliablity of our trucks. IE, new tranny mounts coming soon. As well as all the a-arm mount reinforcements.
Originally Posted by rynomx785
LCA's, UCA's, tie rod extensions, and brake lines. You should get more travel because you will 3" wider per side and the coilover should be mounted at a little bit more of a angle.
Yeah you need longer brake lines
Mid-travel Sneak Peak
http://liftedimports.com/index.html
http://www.youtube.com/user/LiftedImports
06 SMOKE SE KC 2WD TITAN /AEM INTAKE/FLOWMASTER 40/CST 4" LIFT SPINDLES/2.5 X 8" TRAVEL RADFLO COILOVERS W/ REMOTE RESERVOIR / PRG DELUXE MID-TRAVEL KIT /DEAVER 2.5 MINI PACK/2.5 X 10" TRAVEL RADFLO REAR SHOCKS /PRG OFF ROAD TRACTION BARS/ CST CARRIER DROP/PRG HD SHACKELS/ULTRA ROUGE 17X8 WHEELS/37X12.50R17 HANKOOK DYNAPRO MT/HOOPERS CUSTOM 4.56 GEAR INSTALL W/TRUETRAC AND MAG-HYTECH DIFF.COVER/ALLIED MOTORSPORTS PRG MID TRAVEL SET UP CUSTOM FAB FRONT & REAR BUMPERS/BULLY DOG HIGH OCTANE TUNE +2* DISABLE WIDE OPEN THROTTLE GOVERNOR
