Old 10-10-2004, 11:19 AM   #13 (permalink)
vansd1
Originally Posted by mininsx
Still no luck, would it matter if you have a king cab and I have a crew?
How did you figure it out in the first place?
Maybe my box is fried...
I have located the correct blue wire (the smaller of the two) with the method you suggested, but I still cannot get it to work...
ARGH
i have a crew cab too so that doesnt make a differance. check all of your wiring again......make sure that blue wire is the one that when grounded rolls your window up. also make sure you used the redw/white stripe for positive and black for negative, and the white with the blue stripe for your 12v ignition switch. test that purple wire coming off of the door lock motor and make sure you get current when you hit the lock button on your key fob for a split second. i am not trying to say you are doing anything wrong but after i had mine working i went to actually install it by running the wires with the existing factory wires and i switched the blue and green wires. so check and recheck and make sure your power window controlls are plugged in and then just push the lock button twice with a short pause in between.
good luck
vansd1 is offline   Reply With Quote
