Old 10-25-2009, 11:43 AM   #26 (permalink)
TitanBlue
TitanBlue's Avatar
Re: question about ipdm relays
Originally Posted by Rabjr5 View Post
switch the fog lamp relay & ecm relay or the rear window defroster relay.... Fine the diagram of the IPDM in the
"Stall after rough idle?" Thread.......
Look at the diagram of the IPDM and orient the board so the the 45 degree angle of the edge of the IPDM matches your IPDM, since the relays are not marked just to be SURE that you changed the right relay.......
Excellent post.
I just got done writing down a description of the board, orienting it by the 45 Degree Beveled Edge, in my iPod Touch "Memo" Program. Good info to have with you, just in case.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars, UpRev Osiris Tuner 93 Performance Tuned, 18" SE Rims, Functional Hood Scoop, Custom Graphics ...
MD Chapter Director
TitanBlue is online now   Reply With Quote
