Thread: towing and LT's
Old 10-26-2009, 08:48 PM   #11 (permalink)
loufish
loufish's Avatar
Re: towing and LT's
To the OP...
The factory "P" rated tires that came with the Titan have the capacity for towing, provided you don't overload it...
LT tire will give you more capacity at higher pressures, and of course a stiffer ride due to the all ready mentioned stiffer sidewall.
BTW You don't need "E" rated tires....
PRG Performance Kit w/SAW's
Pro Comp heavy & loud 35" Extreme A/T tires on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
2002 Honda XR650R
