Old 10-12-2004, 05:09 AM   #8 (permalink)
Mike H.
Mike H.'s Avatar
Originally Posted by 1BadTitan
Yea the bushings are tight and make it feel like it's "spring loaded" pulling back up. Its OK
That was a b!tch on mine! I absolutely could not do it by hand alone. Had to use pry bars to get some extra leverage on them to be able to start the nut. Knowing what I know now, I would have rigged up a small turnbuckle with wire around the top and lower arms to pull 'em back together. That is more or less what I did with the wire alone.
Mod links (clickable):
