Originally Posted by brooknasty
Need help. I plan on getting 18x9 Ballistic Wizard wheels and 325.65.18 tires. The wheels come in 0, 14, and 30 offset. I have a 6" Procomp1 suspension. Which offset should I get? Is it the more offset the more they tuck in and the less offset the more they stick out? Which offset would rub none or the least? Any help appreciated.
Yep the more offset the more tucked in, the less offset, the more of a deep dish wheel, and the more likely to rub when turning the steering wheel.
A 9" width wheel with 0mm of offset with have 5" of backspacing, (because the center of the rim is 5" not the 4.5" you might expect, because a 9" rim actually measures 10"). So, +14mm would be about 0.55", and the backspacing would close to the stock 5.5" at 5.55". With a PC lift this would work, but the 0 mm would look a little better, but maybe a little trimming.
