Were your tires cold when you checked them? If they were then when they get hot they are running @42 PSI. That means they are standing on the middle of the tire and your wear issue is explained. I run mine at 32PSI cold.
Crew Cab,Pearl White,LE,Venture Clear Bra, Debadged, PML Dif Cover, 285/60/18 Nitto Terra Grapplers & Stillen BBK
