Have you had the brake TSB done to your truck?
The TSB says they've found that the pistons in the brake calipers can stick. Sticking calipers can cause greatly increased wear, pad material deposit on the rotors (causing brake shimmy), and overall crappy brake performance.
Part of the TSB is to lube the caliper pistons with a special, mo better grease that prevents their sticking.
MY04 SE King Cab 4X4 SOLD!
