"Is best buy fine?"
For doing an elaborate car audio install? I wouldn't think so. I would suggest that before you sign any deal and fork over any cash, that you get a complete and detailed list of everything that a potential installer would install and where & how it would be installed. Then you can post that list here & get some suggestions. Also, unless an installer had done an install in a Titan, I'm not sure they would know how to get the dash apart without scratching anything, or how to get the door panels off, will they be installing any sound deadening/insulation, will the Rear A/V controls work, will the steering wheel controls work, what speakers & how will they be installed, etc. Also, if they are competent, they should have photos of prior installs and be able to provide some references.
