Originally Posted by drags1998
WOW, a heater problem, and a squeek and your going to JUMP SHIP!!!!!! sounds to me like YOU need a new mechanic, Not a 10,000 BATH!!!!!!! The rattle in the dash is a EASY fix!!! the ticking is a 5min. fix!!! and without knowing more about the heater prob. its hard to say whats wrong, but, it CANT be that tough!!!! good luck with the Ford, YOU'll NEED IT!!!!!
Actually, the rattle in the dash is not a simple fix, unless you call taking the dash apart simple. The ticking problem is also not a '5 min. fix', as resetting the spark plugs did not work. And yes, three trips to the dealer and a control unit later...still no heat. I'll keep you guys posted on the 150. Like I said, I'm not bashing Titan...wicked truck, I just think they have a little work to do to get it right.
