Old 10-23-2004, 03:50 PM   #8 (permalink)
NorCal 4x4
NorCal 4x4's Avatar
Originally Posted by SDGator
Hey everyone,
I'm a new member here and I'm looking to pull the trigger soon on a LE CrewCab 4x4. Anyways, I am debating on whether to get the 4x4 stand alone or with the Offroad Package (and Big Tow). I plan on doing some offroading down here in Southern Cali, but I don't plan on towing anything. Can someone offer any insight on why you did or did not get this option? Thanks for your help. I'm looking forward to owning one of these rigs soon!
Sean
What this comes down to is do you want VDC, E-LOCKŪ, or neither. I would go for the VDC based upon your intended usage. [Personally I would go for the SE with E-LOCKŪ, and maybe with VDC instead if they offered it on the '05 SE].
On the '05 Titans, (according to the nissanusa.com site's Design your Nissan section), the only way to get VDC, (search on VDC for the pros & cons), is on a LE, with the side-air bag package.
1) On the LE 2x4 with the Big Tow, (BT).
2) Or on the LE 4x4 without BT and without Off-Road, (OR).
If you get the 4x4 LE with BT, you must get the OR, (as you stated). And the OR comes with E-LOCKŪ which means you won't get VDC.
So, you must decide if VDC is worth more to you than the E-LOCKŪ. Sounds like it would be, for your case, but search and read the pros and cons of VDC and E-LOCKŪ, [a.k.a. e-locker, elocker, locking differential, lock, etc. for search].
BTW, for the LE models it looks like the final gear ratio is the same as the BT and/or OR Pkg. So you will get the 3.357:1 ratio "similar to a four-speed automatic 4.10:1", even without BT & OR.
So your '05 4x4 LE CC w/o BT & OR would have 7200 lbs. towing, 1162 lbs. payload. Side air bags can be added with or without VDC.
If you don't care about VDC, you can get more towing and payload with a SE, and still get the side airbag pkg.
Remember this is for LE '05 models only, and from the nissanusa.com website.
