i know we have leaf springs in the rear, but from that article seems a little labor intensive but can be done.
I persoanlly can HIGHLY recommend airbags, i used them in my Jeep GC to level the *** end. (like i said i had ciol-overs in the rear) but seems like the pictures show leaf spring applications) theare fairly expensive $150 and up i think, but let me tell you they work!!!!!!! I would aslo highly reccomend the on-boatd air pump (as opposed to the bumper mount air inlet that you have to fill from a outside source; ie bicycle compressor) when not in use you deflate them to a minimum 5 psi,and it's like they arn't even there. i usaully ran around with them a t 11 psi cause on my GC i found that to be the best ride, it firmed up the ride just evough)
anyway when loaded i inflated them to 30 psi and the rear leveled out nicely.
I had AIRLIFTS for me and they were great. I had mine proff. installed as i wanted to guarantee no leaks which they never did even after 2 years.
[FONT=Comic Sans MS][SIZE=5]This Boy Just Ain't Right[/SIZE][/FONT]
All Mods removed, none worked for me, drives much better stock
