Old 11-04-2004, 09:26 AM   #5 (permalink)
kevstitan
Originally Posted by Retriever
How is the rear brake light connected anyway?
The brake light has a wire that runs down through the rear rack and into the bed. The end of the wire has a plug on it. According to the instructions you're supposed to install this plastic thing on the bottom of the passenger side utilitrack rail and run the wire inside that to protect it. There is a rubber plug somewhere on the side of the bed that you run a wire through and then plug it in somewhere through there. This probably isn't the best explanation as I only read the instructions briefly. Seemed like a lot of wasted effort to me and with the light there it kind of limited the utility of the rack. I had to remove it to be able to mount my kayak saddles.
kevstitan is offline   Reply With Quote
