Originally Posted by TitanBrian
No nav system installed, but my tire pressure alert says I'm low with the lowest tire on the truck at 34psi. It alarmed yesterday with the coldest outside air temp of the season. Drove it to heat up the tires as much as possible, but it won't go out. Looks like I gotta add a few psi or just live with it. I like the ride of the lower pressure. I recall the manual saying it should trip at around 28psi, which is reasonable, but 34??
I had the same issue with mine. As ridiculous as it sounds, I released the air pressure in each tire until it reached about 10lbs. Afterwards, I filled them back up to 33lbs. I did them all individually, letting air out, putting air in, and moving to the next tire. Once I was finished, I got back in my truck and drove it. After about 2 minutes or so, the light went out.
