I didn't say LSD, I said automatic locker, they are two completely different things, as are selectable lockers (like the E-locker and ARB) and auto lockers. A limited slip isn't a locker to begin with, hence the name, most use clutch packs to reduce slip. Selectable lockers act like spools when engaged, both axles turn at the same speed. Automatic lockers keep either axle from turning slower than the ring gear.
