Old 11-05-2004, 12:00 PM   #14 (permalink)
OnebadSE
Banned
Originally Posted by sammy sandbag
I didn't say LSD, I said automatic locker, they are two completely different things, as are selectable lockers (like the E-locker and ARB) and auto lockers. A limited slip isn't a locker to begin with, hence the name, most use clutch packs to reduce slip. Selectable lockers act like spools when engaged, both axles turn at the same speed. Automatic lockers keep either axle from turning slower than the ring gear.
You either have a LOCKER, which you select when you want it locked, or an LSD....which most certainly DOES lock both rear wheels together when one slips a certain percentage of the opposing wheel. Different companies have a different percentage of slip before locking but they do lock. Some are centrifical while others use a clutchpack. You'll have to explain just what an auto-locker is. I've never heard of such a thing. If its unlocked then locks by itself when one wheel slips, it's a Limited Slip, not a locker.
OnebadSE is offline   Reply With Quote
