7-Speed Tranny and 2.93 Rear End = SUCKS! - Nissan Titan Forum
2016 Titan General Forum General discussion forum for the new 2016 Nissan Titan.
post #1 of 31 (permalink) Old 02-14-2017, 07:18 PM Thread Starter
TITANUP2017's Avatar
Garage
iTrader Score: 0 reviews
New 7-Speed Tranny and 2.93 Rear End = SUCKS!
If you own or have driven a 2017 Nissan Titan, one of the first things you'll notice is how sweet the engine is and almost immediately after you'll notice how the transmission completely makes it perform like a V6. The rear end axle ratio doesnt help only makes it worse. The other makers are in the low to high 3's on half tons. The higher the ratio the more your able to put the power to the ground...simple logic.
TITANUP2017 is offline
Advertisement
post #2 of 31 (permalink) Old 02-14-2017, 08:10 PM
Originally Posted by TITANUP2017 View Post
If you own or have driven a 2017 Nissan Titan, one of the first things you'll notice is how sweet the engine is and almost immediately after you'll notice how the transmission completely makes it perform like a p-ussy. The rear end axle ratio doesnt help only makes it worse. I'm sorry did you say the axle ratio is below 3??? Yes folks its the lowest ratio of any half ton truck on the market...I think ever produced. The other makers are in the low to high 3's on half tons. The higher the ratio the more your able to put the power to the ground...simple logic.
Old Titans were the exact same way... I think 2.94 standard and 3.3ish available with the Big Tow package. A lot depends on the gearing in the transmission as well. The 7 speed has an exceptionally tall first gear.
satxwy is offline
The Following User Says Thank You to satxwy For This Useful Post:
Titantred (02-17-2017)
post #3 of 31 (permalink) Old 02-15-2017, 09:00 AM Thread Starter
Garage
Re: 7-Speed Tranny and 2.93 Rear End = SUCKS!
3.3 is where everyone else starts out and the high 3's with tow package (up to 3.92). I've driven a 3.92 ram with similar HP as the TITAN and its a completely different truck. Chirps tires off the line and even in second. You might as well put a V6 in it if you're going to have a tranny that restricts it from its true potential.
post #4 of 31 (permalink) Old 02-15-2017, 10:34 AM
If you own or have driven a 2017 Nissan Titan, one of the first things you'll notice is how sweet the engine is and almost immediately after you'll notice how the transmission completely makes it perform like a V6. The rear end axle ratio doesnt help only makes it worse. I'm sorry did you say the axle ratio is below 3??? Yes folks its the lowest ratio of any half ton truck on the market...I think ever produced. The other makers are in the low to high 3's on half tons. The higher the ratio the more your able to put the power to the ground...simple logic.
This is the fastest Titan yet. It is also one of the fastest half tons currently available. https://youtu.be/CaCjsMMScgM
hondarider65 is online now
The Following User Says Thank You to hondarider65 For This Useful Post:
post #5 of 31 (permalink) Old 02-15-2017, 10:57 AM Thread Starter
Garage
Yes its quick but you have to practically floor it for it to downshift. All the Ford engines are faster btw. Being "ONE" of the fastest doesn't mean anything. The quickness is just a testament to how great the improved engine and weight reduction really is. Imagine the possibilities if you could actually access its FULL potential with a quicker shifting more refined tranny and a higher axle ratio.
post #6 of 31 (permalink) Old 02-15-2017, 05:42 PM
Supastipa's Avatar
The power delivery on the new Titan is definitely different. I drove an 04 with the 3.36 for 12 years. It was crazy quick off the line, you'd have to feather the throttle so you wouldn't roast the tires, especially around corners but it fell a bit flat up high in the rpm range. The new truck has mad power available up higher in the RPM range. It crazy quick on the freeway and has legs for days. I've found the trans mapping is a lot better in Tow mode. I'm really looking forward to see how it tows this summer, especially in the mountains. It seems to have done pretty well on the Ike gauntlet test on TFL so my hopes are high. Throw out the subjective score and it's right there with Ford's 10 speed 3.5 f150, and finding one of those with a center console, locking diff and cargo management system, at least around here, is gonna cost you big.
2017 Nissan Titan Half-Ton: Ike Gauntlet Extreme Towing Review [Video] - The Fast Lane Truck
2017 Titan Pro-4x w/ utility pkg.
**SOLD**2004 Titan 4X4 LE KC w/ BT OR - "YEAR 1 CLUB
Supastipa is offline
The Following User Says Thank You to Supastipa For This Useful Post:
hondarider65 (02-15-2017)
post #7 of 31 (permalink) Old 02-15-2017, 06:08 PM
Pale Rider's Avatar
iTrader Score: 4 reviews
ya`ll should have bought the Ford instead of *****ing. ya`ll went for a test drive righttt???
Pale Rider is offline
The Following 3 Users Say Thank You to Pale Rider For This Useful Post:
hondarider65 (02-15-2017), IMADOGMAN (02-18-2017), nightowl (04-02-2017)
post #8 of 31 (permalink) Old 02-15-2017, 06:19 PM
Supporting Vendor (Gold)
iTrader Score: 2 reviews
Apparently not
lizardking is offline
post #9 of 31 (permalink) Old 02-15-2017, 06:20 PM
Some of us have brand loyalty and just don't care for fords
post #10 of 31 (permalink) Old 02-15-2017, 06:34 PM
Tonelocg's Avatar
Garage
some of us have brand loyalty and just don't care for fords
sent from my iphone using tapatalk
word!!!!!
Tonelocg is offline
post #11 of 31 (permalink) Old 02-15-2017, 09:09 PM
HRTKD's Avatar
Garage
I recently purchased an F-350. The original order mistakenly went in with a 3.31 axle ratio. When the dealer and Ford couldn't get the order changed I cancelled the order and re-ordered with the (correct) 3.55 axle. Given what I tow and where I tow I would have taken 3.73 if it was available. I can't imagine what it would be like to tow with the 2.94 rear end some of you guys are dealing with.
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
2017 Ford F-350 CCLB 6.7l Lariat - The Towing Beast
Jim aka Bionic Whore™
HRTKD is offline
post #12 of 31 (permalink) Old 02-16-2017, 09:42 AM Thread Starter
Garage
Good point. TFL also negatively commented about the tranny if you recall as one of its only major inhibitors. Exactly high RPM is fine. Low end is lacking given the current gear ratio. You really have to stomp on it for it to downshift.
post #13 of 31 (permalink) Old 02-16-2017, 09:43 AM Thread Starter
Garage
weerrrrddd!!!
post #14 of 31 (permalink) Old 02-16-2017, 09:47 AM Thread Starter
Garage
Yeah I agree. Anything lower than a 3.31 is really doing a disservice to towing and engine performance.
post #15 of 31 (permalink) Old 02-16-2017, 04:07 PM
Lee-the-Impaler's Avatar
Location: WESTERN (actual) Colorado.. where the mountains are.
Garage
iTrader Score: 1 reviews
Now I have several comparisons here, though I'm currently dragging with a first gen titan with the 2.94, It severely outperforms any other half ton I've towed with (which runs the gamut between a '90 F-150, to a '10 ram) When I'm climbing divides with an overloaded trailer, I am constantly wishing for a gear between second and third. Keep in mind, when doing this, I MUST be in manual mode and over 2kRPM or my tranny will start cooking in a big hurry. While I don't have a comparison on the new 7speed, it seems to me that more gears would be a great benefit. However, it's easy to picture the mapping being useless, because nowdays, it's all about emissions, MPG, low noise, comfort, etc: Basically, the points of a pickup that don't matter for **** when it comes to actually getting something beyond cruising town with it done. Now the first gen motor and chassis are more than up to the rigors of heavy towing, but the tranny, suspension, and rear end leave much to be desired. They will however, get the job done if you're careful and smart about it. It's hard for me to believe that with 2 more gears, and more torque that the second gen isn't superior in this regard. It is disappointing that the new flavor still offers just the 2.94, and 3.36- But it isn't really shocking.
But, look now at the points made about the second gen, it revolves around the looks, the lack of a console shifter, the 'more refined' interior, ETC. That's because in these times, a half ton pickup is built to appeal to car people who are unlikely to ever put payload and towing cap even near the limit, and will never likely see greater off-roading duty than backing onto thelawn to load up the tree trimmings. With that in mind, if you are looking for a pickup to do the dirty, heavy dusty that pickups were invented to carry out, you're out of the nissan market, because you're going to need a one ton. I don't know about ram, but the current gasoline 3/4 tons in the ford and GM offerings aren't even up to par with my 140Kmi, 8yo first gen, EXCEPT: in transmission heat. If I had the choice between any of them, and my spine-cracking, ultra loud, non-turbo '89 F-350 (with worn out bench seat, 0 cup holders, no AC, ETC) to get a big haul done, it'll be the old rattletrap any day. (Do keep in mind this is only for the gassers, which might not be 'fair' pitted against a 7.3 IDI with a 5sp manual) I can't do anything but speculate without any hands on knowledge on the cummins XD: Oddly, the dealership isn't too keen on letting me hook 9.4K of scrap steel to the *** of an XD for a test drive. Back to the fluffy stuff: a second gen Titan could never work for me until my oldest daughter heads to college anyway, I need a six seater for my daily ride (Which also rules out my '89 by half).
But thanks for the report, Maybe I need to rethink on trying to get a second gen motor and tranny once I get the dana 60 and gm 9.25 (in 3.73) modded up for my Titan. Your post re-opened the brainstorm line of a six speed manual conversion as an alternative. Either one would require ECU foolery that is FAR beyond my ability, or a strip down and standalone, which..is the same category. Luckily, i know some folks, unfortunately, my wallet cries at the thought. Keep us up to date if any 'easy fixes' come to light on the shift-lack of the second gen powertrain.
Lee-the-Impaler is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
tranny on its way out and rear end is joining schmidtmike76 Titan General Discussion 14 09-23-2015 09:09 PM
Rear end or Tranny problem?!?! MyNameIsZbob Titan General Discussion 4 08-01-2014 07:31 PM
Maybe a 10-speed tranny? AZPRO4X Titan General Discussion 0 12-03-2012 02:57 PM
trashed rear end or tranny.... [T.J.] Titan Problems & Dealer Service 15 08-13-2010 09:39 AM
You may post new threads
You may post replies
