Old 11-17-2004, 10:04 AM   #12 (permalink)
pagerdaddy
pagerdaddy's Avatar
Originally Posted by Half Shovel
A much larger issue is my trust of the vehicle. Since so many aspects of this vehicle were assembled or designed poorly, why would I trust the drivetrain?
HS, I don't know if it will ease your mind any, but I think most of the problems
are related to the Canton assembly plant. If I have it right, your engine was
built in Tennessee, and your tranny came directly from Japan. I bet the
screw up on your exhaust manifold happened in Canton. The problem with
the diffs seems more likely to be more of lack of fluid, rather than a design
issue. You may want to check the transmission fluid, also, just to be on the safe side.
Steve
pagerdaddy is offline   Reply With Quote
