Old 11-19-2004, 09:11 AM   #4 (permalink)
SupraTitan
SupraTitan's Avatar
Looked it up the stock plugs are the NGK double platinum. They retail for over $11 a piece!, the iridium ngk plug for the titan retails at just over $7. Definatly not worth swapping, espcially from a performance stand point. Usaully you will find the best performance with a fresh set of $1 copper plugs, at least thats what i've always found worked the best in my supra which calls for a plat. plug. Just require yearly changes.
04 Titan CC,BT,OR,4X4, 5333lbs, 15.42@88.79mph stock
Zoomers catback, 2* timing advance
SupraTitan is offline   Reply With Quote
