Old 11-21-2004, 01:49 PM   #15 (permalink)
import2nr
import2nr's Avatar
Send a message via AIM to import2nr Send a message via Yahoo to import2nr
I used the radio fuse for the remote wire. And I just taped in to the speaker wires coming from the back of the radio instead of using the RCA’s. And I think the Down firing subs sounds allot better than the up firing ones. It sounds deeper in my cab anyway. I didn’t drill any holes for the ground wire I simply used one from the seat frame. I thought I would have ground noise but I have none. And as for the power wire I simply poked through under the passenger’s dash where I believe it’s the ac drain. I didn’t want to holes in the truck so I also used Velcro to hold the amp in place.
import2nr is offline   Reply With Quote
