On a lot of new cars now days, I run the stock plugs. The factory designs cams, & cyl heads for performance, economy, and emissions, then they design a spark plug to work with all that. 95% of the time, the best plug for an engine is the one designed just for that application.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
