11-29-2004, 04:45 AM
#1
Rear Window Seals Leaking, rear seatbelts blow
I had 5 people and all their crap in my truck on the way to turkey day. After a while we switched drivers, so I thought I'd sit in the back to see what it was like on the highway. Damn comfortable, except 2 things:
1. My passenger side window leaks around the black seal. The window/seal is quiet, but where the seal meets the door frame there is a good sized leak. I think I might just put silicone caulk in there, rather than go to the dealer for visit number 5,323,432.
2. The rear seatbelts blow. The center one (has been replaced once), locks up if you just lean forward a bit, and then sometimes you can't get it to unlock unless you release it and then let it sit for a bit. The passenger belts lock up pretty easily, too.
So I guess this is the pattern - Truck drives great, awesome passenger compartment, etc, mitigated by wind noise and crappy seatbelts.
HS
