Originally Posted by Clint
Am I wrong? I thought with tow/haul mode all you do is turn it on and it changes the shift points in the computer commands to the transmission. You shoudn't need to turn the overdrive off.
Clint
Yep, you're right that tow mode will change the shift points. But it won't keep it out of overdrive. Always tow in 4th. If you insist on towing in overdrive on flat roads, then keep a sharp eye on the tranny temp and knock it into 4th if the guage starts to inch higher than normal operating temp.
'04 Titan SE King Cab 2WD Deep Water
Popular Pkg w/ Captains, Big Tow
Added: OEM step rails & splash guards, leaf spring helpers, Line-X, TruXedo LoPro tonneau, Wade In-channel window visors
Born 6/3/04, Bought 7/5/04
