Old 12-16-2004, 12:51 PM   #7 (permalink)
CaliforniaTitan
CaliforniaTitan's Avatar
Originally Posted by Optimist
If you shop dealerships you may find a service manager to allow on your 1st try new rotors. Worked for me anyway. Demand new rotors, you might just get them.
Agree...use common sense on them.
IF they want to just 'turn them' then ask the following.
"Ok, correct me if I am wrong...but rotors warp due to heat correct?"
Answer - Yes.
"Ok, so if that's the case, then removing metal with turning them makes them thinner correct?"
Answer - Yes.
"Well then, if the rotors are thinner and there is obviously a heat issue that warped them to begin with, why is turning the rotors going to do me any good? If your going to remove metal by turning them, then they will just warp that much faster correct?"
Chris
