Originally Posted by the head
One of the things I can monitor on the CANscan is the airflow at the meter. I was also going to look at the flow of the stock air filter vs. the K&N drop-in (I have the inner tube cut out of my box) and then hopefully do the Volant.
That'd be great to see more than one comparison. I've tested with the K&N and the stock filter, both with the airbox mod. I have no data on either filter with unmodified stock box, though.
I wonder if it will actually give you the air mass, or density since this is what a hot-wire type MAF does, and then calculates that to cfm? Just curious how the MAF calculates airflow without reading velocity or cfm directly. Will a standard OBDII scanner display airflow data?
Thanks
