Old 12-18-2004, 04:26 PM   #7 (permalink)
CaliforniaTitan
CaliforniaTitan's Avatar
'05 rotors are the same as the TSB ones you get on the '04.
As far as the post above mine here...That sounds like a dealer response until you take them for a ride and show them you drive like a normal person and that you put apprx 30-40k on EACH vehicle you have a year and have no issues on any of the others...
After going through it with the '04 and now starting with the '05 (just over 5k on the new one and have the judder the first time now)- there is a problem with them...whether it be the Master cylinder is too biased to the fronts, the calipers not releasing correctly and dragging, the pad and rotor material being cheap or whatever it is the bottom line is Nissan needs to get the real fix out and not a bandaid...THEN you will see a decline in postings of this problem on this and other Titan forums.
Chris
