Originally Posted by tnbowhunter
I like to check mine after sitting overnight, that way I can get a truly accurate reading. If you check them in the morning or after it has sit without driving for several hours and they are at 42 I would definitely air them down to 35 psi.
Just remember there are three different tires on the Titan
1. 285/70517 with the OR PKG max pressure of 35PSI (I have these)
2. the 18" tires (max 44 psi)
3. the 17" tire for the XE PKG (not the same tire or size as OR PKG)
All of these have different tire pressures check you sidewall for your max cold inflation pressures then can play with your air pressures from there to suit your needed.
