Originally Posted by Mike Up
I believe the above is correct as the Hemi is rated at 345 Hp and 375 ft/lbs of torque. A performance modification site has the Hemi dynoed almost the same as Group 1's findings. The Hemi dynoed at 261 Hp & 288 ft/lbs Torque. See here.
I truly now believe are 'true' ratings are 341 Hp & 394 ft/lbs Torque and there is a 25% driveline loss.
Thanks guys for the good information on the compilation.
Have a good one.
With a 25% loss I can see where you come to your conclusion. I think it's pretty damm close from what we have seen...
I'm definitely with you on the 25% loss....
