Door Handle Problems Anyone?
Hey all,
Anyone got any suggestions?
I keep having the rear driverside door handle freezing shut on me. I b*tched to the dealer, the said there was some water in the greese in the handle, and that they would repack it, I told them no way, replace it - so they did.
Now the da*n thing is freezing again, you can open it if you pull hard, but then the handle is stuck out and the door wont close - the first time it happend, I had to bungie the door shut to get it to the dealer.
It is soooo annoying not being able to use that door - I tried spraying silicone in it, did nothing! I do not have time in the morning to use a hair dryer on it it is rediculous. Anyone have this problem, or any suggestions on how to fix it?
They should have listed on the sticker that the truck is use in warm climates only. I won't even get into all the noises the thing is making with the cold!!!
Help!! I even had the thing idling today for about three hours while I was at work (I work out doors, was dealing with snow today) with the heat on high, and it still did not unfreeze!!
Thanks, I just had to grip about it!
