Old 12-24-2004, 10:33 AM   #31 (permalink)
Finnattic
Finnattic's Avatar
Thumbs down Tornado
Originally Posted by Titan_TX
It out performs the others in normal life expectancy? Sorry but if you believe a dyno, you would believe the tornado device actually gains HP. LOL
At this current time, Amsoil and Redline are the market leaders in oil. At 6k of miles, they show less wear than RP would show or any other oil.
Lab testing is the REAL TRUTH. Unless all you care about is your HP, not how your engine wears and lasts overtime.
No you didn't bring a tornado into this. The top engine builders in the world didn't use a tornado or Amsoil to win the compettition they used RP.
http://www.royalpurple.com/engmasters/emc04.html
I use RP with good results, increased power, cooler running engine and better gas milage.
Independent tests clearly document the power, protection and performance of Royal Purple® Motor Oil.
400%
Greater Film Strength - Reduces Wear1
300 - 500%
Greater Oxidation Stability - Increases Oil Life2
1.5 - 3.0%
Increase in Engine Horsepower and Torque
3 - 5%
Saves Fuel over Other “Energy Conserving” Oils
> 20%
Reduces Harmful Exhaust Emissions
Up to 12%
Reduces Engine Heat
Summary of Tests -- Some data fields are blank because the data field was not a part of the original test criteria.
Data Source: “Drop Dead Center TV” - August 2004
Description of Test: Replaced existing conventional motorcycle oil with Royal Purple's Max-Cycle® in a brand new Rev-Tech engine. Temperatures continuously monitored using a thermal imaging camera.
Engine Type
Performance Improvement
Gasoline
An average temperature Reduction at Idle of 11° F
Greater temperature reductions were expected at higher rpm's.
Data Source: Performance Auto & Sound Magazine - January 2004
Description of Test: Replaced existing engine oil and transmission fluid with Royal Purple's 5W30 Motor Oil and Royal Purple's Max-Gear® 75W90 transmission lubricant in a 1999 Nissan Maxima.
Engine Type
Gasoline
Horsepower
3.0%
Torqu
Data Source: Longview Inspection - January 2004
Description of Test: Replaced existing OEM motorcycle oil with Royal Purple's Max-Cycle® 20W50 in a 2003 Harley Davidson Soft-Tail Standard with a Twin Cam 88 engine to determine if switching to Royal Purple® would reduce operating temperatures. Temperatures continuously monitored with a FLIR Model 550 Radiometer during testing.
Engine Type
Gasoline
Temperature Reduction
24° F - 44° F
Data Source: D & D Performance Enterprises - December 2003
Description of Test: Replaced existing synthetic motorcycle oil with Royal Purple's Max-Cycle® 20W50 in a 2004 Harley Davidson 1200XL (Sportster Roadster) on a Super Flow Cycle Dyne Eddy Current Load Dyno.
Engine Type
Gasoline
Horsepower
1.2%
Torque
1.3%
Data Source: Tuner Performance Reports Magazine - Issue 003, Fall 2003
Description of Test: Replaced existing stock motor oil with Royal Purple's high performance motor oil in a 2002 Honda Accord and tested on full chasses dynamometer.
Engine Type
Gasoline
Horsepower
1.8%
Torque
Data Source: Drag Sport Magazine - April 2003
Description of Test: Replaced existing 20W50 engine oil with Royal Purple's 10W30 Motor Oil in a 1994 SR20DET Turbo 2.0L engine from Japan fitted in a 1989 240 SX and tested on full chassis dynamometer.
Engine Type
Gasoline
Horsepower
3.2%
Torque
1.5%
Data Source: “Hot Rod TV” - December 2002
Description of Test: Replaced existing mineral oil to Royal Purple's Racing 21 motor oil (viscosity similar to 5W30) and Max-Gear® 75W90 in a 1962 Ford Galaxy.
Engine Type
Fuel Savings
Gasoline
City
23.4%
Highway
28.8%
Data Source: “Hot Rod TV” - May 2002 / Hot Rod Magazine - August 2002
Description of Test: Replaced existing 20W50 engine oil, GM Dexron III® ATF fluid, and 75W90 differential fluids with Royal Purple's 20W50 Motor Oil, Max ATF® and Max-Gear® 75W90 in a 400 HP ’65 Mercury Comet and tested on full chassis dynamometer.
Engine Type
Gasoline
Horsepower
2.5%
Torque
1.5%
Data Source: North Carolina State University - July 2002
Description of Test: Brand Name “energy conserving” 10W30 motor oil vs. Royal Purple® 5W30 in 25 vehicle fleet test (North Carolina Highway Patrol).
Engine Type
Fuel Savings
Emissions Reductions
Gasoline
2.5%
Description of Test: CLR Research Engine Test (15W40 motor oils).
Engine Type
Fuel
Savings
Emissions Reductions3
Royal Purple® vs.
Brand Name mineral oil
Diesel
Soot
NO2
CO
3.68%
@1200 RPM
11.75%
8.5%
17.7%
2.48%
@1600 RPM
17.58%
-6%
21.0%
Royal Purple® vs.
Premium synthetic oil
Diesel
3.37%
@1200 RPM
4.3%
7.2%
28.15%
1.48%
@1600 RPM
3.0%
same
33.87%
Description of Test: CLR Research Engine Test (5W30 “energy conserving” motor oils).
Engine Type
Fuel Savings
Royal Purple® vs.
Gasoline
4.5%
@1200 RPM
5.0%
@1600 RPM
NO2 was over 50% lower @1200 RPM where complete combustion occurred.
CO levels with Royal Purple© were low at all loads. Royal Purple© tended to prevent incomplete combustion.
Royal Purple® vs.
Gasoline
2.5%
@1200 RPM
3.0%
@1600 RPM
Description of Test: EPA 75 (city) and HWFET (Highway Fuel Economy Test) tests comparing a Brand Name 10W30 “energy conserving” motor oil to Royal Purple® 5W30 motor oil.
Engine Type
Gasoline
CO
HC
NO2
EPA 75
29%
EPA 75
16%
EPA 75
1%
HWFET
62%
HWFET
19%
HWFET
-23%
Data Source: “Horsepower TV” - May 2002
Description of Test: Replaced existing 5W30 synthetic engine oil, GM Dexron III® ATF mineral oil and 75W90 synthetic differential fluid with Royal Purple's 5W30 Motor Oil, Synchromax® manual transmission fluid and Max-Gear® 75W90 in a 2000 Camaro SS and tested on full chassis dynamometer.
Engine Type
Gasoline
Horsepower
2.9%
Torque
Data Source: Hot Rod Magazine - March 2002
Description of Test: Replaced existing mineral oil in new GM 383 V-8 Motor.
Engine Type
Gasoline
Horsepower
1.7%
Torque
2.0%
Data Source: Oklahoma State University - 2001
Description of Test: Brand Name 15W40 engine oil vs. Royal Purple® 15W40 on full chassis HD truck dynamometer4.
Engine Type
Fuel Savings
Diesel
4.4%
Smoke Opacity (SNAP Test)
22%
Horsepower
2.8%
1
Film Strength based on comparison of leading 5W30 vs. Royal Purple® 5W30 Motor Oil in Falex No. 1 "high pressure" test. (Scar widths mm. Leading 5W30 motor oil: 5.9 mm - scored; Royal Purple® 5W30 Motor Oil: 1.4 mm - polished.)
Oxidation life based on U.S. Bureau of Standards TFOUT oxidation test (leading synthetic 5W30 oil - 409 minutes; leading 5W30 mineral oil - 246 minutes; Royal Purple® 5W30 - 1300 minutes.)
3
Terminology:
CO = Carbon Monoxide (a poisonous gas);
HC = Hydrocarbons (unburned fuel - normally occurs when fuel to oxygen mixture is too rich);
NO2 = Nitrous Oxide (cited as a contributor to smog, ozone, acid rain and regional haze and is exacerbated by the elevated combustion temperatures of “lean burn” engines where more oxygen exists than is needed to completely burn the fuel);
HP = Horsepower;
CO and NO2 are typically on polar opposites. When one increases, the other decreases.
Originally Posted by Finnattic
It took graduation from the "School Of Hard Knocks" (Marine Corps), with an associates in "Combat Vet" from Fallujia University to open the door to my dream job.
"Some people live an entire lifetime and wonder if they have ever made a difference to the world, but the Marines don't have that problem..." President Ronald Reagan
"There are only two kinds of people who understand Marines: Marines and the enemy. Everyone else has a second-hand opinion."
If you can read, thank a teacher. If you can read in english, thank a Marine.
By The Grace Of GOD, Guardian Angels Protect Us In Battle
2004 TiTan King Cab 4x4 SE Silver
Big Tow, Off Road Package, Utility Package
Rockford Fosgate
Volant CAI W/ Air Scoop
Borla/Gibson Hybrid Dual Exhaust
Putco Liquid Grill
Cordura Seat Covers
Husky Floor Liners
MB Gunner 6 Gloss Black 20's
Yokohama Parada Spec-X 275/55R/20
275.86 rwhp
341.59 rwtq
1/8 In 9.498 @ 72.06
1/4 In 14.934 @ 90.53
2 Degree Advance
New dyno and track times since new mods to come...
Finnattic is offline   Reply With Quote
