Old 01-07-2005, 03:55 PM   #8 (permalink)
Mike H.
Mike H.'s Avatar
Originally Posted by K-MU
Hey Mike, Ive read a couple of yur threads, seems you installed the tires first, then the front level kit. I want to have the same Nitto tires on the my oem wheels without a lift first, then add the leveling kit.
1.- Did the Nittos rubbed without the front level kit?
2.- Notice any improvement with the kit?
3.- How is the handling on wet highways or streets compared to the oem tires?
4.- Did your gas milage change with the new tires?
THX in advance, and sorry for all the questions...
Mario Camou
1.- No, but I never had it offroad. They may have if I'd have hit the right bump with the wheel turned at the right point.
2.- Other than improved height and look, no.
3.- Similar wet, better dry.
4.- No, they are virtually the same diameter, and the wheels are much lighter than OEM.
You should note that Nitto does not rate the 295's for 7.5" wheels, if I recall correctly.
Mod links (clickable):
